[OpenLayers-Users] limiting a Vector layer to the last feature added
John Cartwright john.c.cartwright at comcast.net
Sat Aug 15 12:28:47 EDT 2009
Thanks for your suggestion Eric.  That was the first thing I tried,
but it doesn't clear the map, even with an explicit redraw()
         vectorLayer.events.on({
	        "featuremodified": mapUpdated,
	        "beforefeatureadded": clearPreviousFeatures,
	        "featureadded": mapUpdated
	function clearPreviousFeatures(evt) {
		vectorLayer.destroyFeatures();
		vectorLayer.redraw();
	function mapUpdated(evt) {
		console.log('Vector layer has '+vectorLayer.features.length+'
features');
		dojo.publish('mapUpdated',[evt.feature.geometry]);
Setting it up this way also seems to clear the newly added feature as
well - when the featureadded handler runs, it reports no features in
the layer.
Is this what you had in mind?
I really appreciate your help with this.
--john
On Aug 15, 2009, at 1:26 AM, Eric Lemoine wrote:
> On Friday, August 14, 2009, John Cartwright
> <john.c.cartwright at comcast.net> wrote:
>> Hello All,
>> I'm using OL 2.8 and trying to implement the behavior where the
>> user can
>> digitize points, lines, or polygons, but only the last created
>> feature
>> will be kept and displayed.  I've attempted this via a handler on the
>> Layer's "beforefeatureadded" event like:
>>    dojo.forEach(vectorLayer.features, function(f) {
>>       if (http://f.id != http://evt.feature.id) {
>>          vectorLayer.removeFeatures([f], {silent:true});
> removing objects within a dojo.forEach loop may not be safe.
> why don't you have you beforefeatureadded listener destroy all
> features (with layer.destroyFeature)?
> Cheers,
>> However,  I find that the previous drawn features remain until the
>> DrawFeature control is changed.  Also as soon as the second feature
>> is
>> added, the code above complains that "f is undefined".  Finally, any
>> features added subsequent to the first do not display in the style
>> defined for the layer.
>> I feel like this should be a simple task and that I'm missing
>> something
>> fundamental here.  Can someone show me what's wrong or suggest a
>> better
>> strategy for accomplishing this goal?
>> Thanks!
>> --john
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090815/d6f8eb29/attachment.html
