[OpenLayers-Users] Bug in Google with overaly example
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Aug 17 01:57:20 EDT 2009
On Tuesday, August 11, 2009, Rodolfo Moreno <rodolfoamoreno at gmail.com> wrote:
> Thanks Eric for your answer. I am overlapping a mapguide layer. I did what
> you suggested but it's not working.
> var dynamicOverlayOptions = {
> buffer: 1,
> singleTile: true,
> isBaseLayer : false,
> visibility : true,
> transparent:true // This is the code added
> Is this property (transparent:true) new?
> I ask about it because my sample works fine 3 months ago.
transparent is a WMS param. It should go in the Layer.WMS params, not options.
> Thanks in advance
> Eric Lemoine-2-2 wrote:
>> On Sat, Aug 8, 2009 at 12:35 AM, Rodolfo Moreno<rodolfoamoreno at gmail.com>
>> wrote:
>>> Hi all,
>>> The google with overlay example from
>>> "http://openlayers.org/dev/examples/"
>>> is working incorrectly. The bug is not only because the worldmap is not
>>> loaded correctly but also because this is covering whole the map and thus
>>> the google layer is not showed, just the worldmap is showed. if you turn
>>> off
>>> the worldmap layer then it's possible to view the google layer. I
>>> realized
>>> about it because I have a similar example overlaping google maps with
>>> mapguide layers and 3 months ago this sample worked appropriately (in
>>> that
>>> moment the last release was 2.6 version) and now I got the same bug, it
>>> means that mapguide layers covers whole map that don't enable to view the
>>> google layers.
>> The layer you put on top of the google layer must be transparent. If
>> your layer if a WMS layer (OpenLayers.Layer.WMS) use transparent:true
>> in the layer params.
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/Bug-in-Google-with-overaly-example-tp3407076p3426344.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
Eric Lemoine
