[OpenLayers-Users] Overlaying Google map Fail with OL.Layer.TileCache but work with OL.Layer.WMS!?
Etides etienne.desgagne at roche.ca
Mon Aug 17 11:19:13 EDT 2009
    I use Tilecache (2.10) on Windows to generate tiles from a WMS service I
created with the GIS Manifold (this GIS do not support the SphericMercator
prj). I’m using Openlayers  (2.8) to create a OpenLayers.Layer.WMS that call
the tilecache.py script to generate the tiles that I overlay over 2 bases
map (Google & Virtual Earth). Switching to any one of this 2 base map let me
see correctly my tiles over the base map. So far so good…
The problem is when I add a second layer of type OpenLayers.Layer.TileCache
to reach directly the tiles from disk generated earlier with the WMS. In
this case, ONLY the overlay with the Virtual Earth work, the tiles are not
showing when switching to the Google base map (I got red crosses for each
tiles).
When looking for the properties of a tile in error, I got
../05/000/000/008/000/000/007.png as URL. I got
…04/000/000/008/000/000/007.png when looking for the same tile (that work)
when overlaying Virtual Earth.
Someone can explain me why the overlay of a Google base map do work with a
WMS layer but do not work when accessing the same tiles but directly from
disk? Why is it working with VE!??
Here is the code:
function init()
            map = new OpenLayers.Map('map');
            var goo = new OpenLayers.Layer.Google("GMaps", {type:
G_HYBRID_MAP });
            var ve = new OpenLayers.Layer.VirtualEarth( "VE Aerial" );
            map.addLayers([goo,ve]);
            // --- Tilecache layer WMS
            var tc_wms = new OpenLayers.Layer.WMS( "My layer
WMS","tilecache.py?",
            {    layers: 'Derechos Mineros',
            format: 'image/png'//,
                 //maxExtent: new OpenLayers.Bounds(-82, -19, -68, 1)//,	 },
        {isBaseLayer: false});
        map.addLayer(tc_wms);
            // --- Tilecache layer... to get tiles directly from disk...
            var tc_cache = new OpenLayers.Layer.TileCache("My layer from
disk",["http://PERCAN1/tilecache/Cache"],
            "Derechos Mineros",
{'format':'image/png',transparent:'true',opacity: 0.5,'isBaseLayer':
false});
            map.addLayer(tc_cache);
            map.addControl( new OpenLayers.Control.LayerSwitcher() );
            map.addControl( new OpenLayers.Control.MousePosition() );
            map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
            if (!map.getCenter()) map.zoomToMaxExtent();
The code from tilecache.cfg:
[Derechos Mineros]
type=WMS
layers=Derechos Mineros
url=http://PERCAN1/test_wms/wms.asp?transparent=true
extension=png
Thanks a lot
Etienne
View this message in context: http://n2.nabble.com/Overlaying-Google-map-Fail-with-OL.Layer.TileCache-but-work-with-OL.Layer.WMS%21--tp3459714p3459714.html
