[OpenLayers-Users] KML reprojection?
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Aug 18 01:59:18 EDT 2009
On Tuesday, August 18, 2009, Jeremy Husmann
<Jeremy.Husmann at critchlow.co.nz> wrote:
> Hello everyone,
Hi
> I am in the process of adding a KML as a baselayer (I was
> quickly helped by Eric and Christopher by finding the constructor attribute
> need for this.).
> Now I seem to have stuck another in relation to projections.
> I have noticed that if I add the KML as the only base layer
> it comes out a bit squashed, when if I don’t change any projection
> settings and just add a WMS layer as another base layer it seems to correct the
> KML. – Unsure if anything is going on behind the scenes (with my KML
> being reprojected?) or if im just missing something extremely obvious. –
> Any help would be appreciated.
What if you remove the TMS layer and have the vector layer as the only
layer in the map?
> function
> mapInit()
> var
> nzBounds = new OpenLayers.Bounds(165, -47, 180, -34.5).transform((new
> OpenLayers.Projection("EPSG:4326")), (new
> OpenLayers.Projection("EPSG:900913")));
> var
> options =
> projection:
> new OpenLayers.Projection("EPSG:900913"),
> displayProjection:
> new OpenLayers.Projection("EPSG:4326"),
> units:
> "m",
> maxResolution:
> 16543.0339,
> maxExtent:
> nzBounds,
> numZoomLevels:
> 24,
> minZoomLevel:
> 6,
> maxZoomLevel:18,
> controls:
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.LayerSwitcher({'ascending':false}),
> new
> OpenLayers.Control.PanZoomBar({zoomWorldIcon:true})
> map = new OpenLayers.Map('map', options);
> map.addControl(new
> OpenLayers.Control.LayerSwitcher());
> var mapnik = new OpenLayers.Layer.TMS(
> "OpenStreetMap (Mapnik)",
> "http://tile.openstreetmap.org/",
> type: 'png',
> displayOutsideMaxExtent: true,
> attribution: '<a
> href="http://www.openstreetmap.org/">OpenStreetMap</a>'
> mapnik.setVisibility(false);
> var
> time = new Date();
> var
> secs = time.getSeconds();
> postCodeKml
> = new OpenLayers.Layer.GML("CoverageTEST",
> "kml/coverage_1.kml?" + secs,
> format: OpenLayers.Format.KML,
> projection:map.displayProjection,
> isBaseLayer:true,
> formatOptions: {
> extractStyles: true,
> extractAttributes: true
> map.addLayers([mapnik]);
> postCodeKml.setVisibility(true);
> map.addLayer(postCodeKml);
> postCodeKml.setOpacity(0.25);
> map.zoomToExtent(nzBounds);
> map.addControl(new OpenLayers.Control.MousePosition());
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
