[OpenLayers-Users] Adding new features: WFS-T PostGIS
Juan Arévalo arevaco90 at yahoo.es
Thu Aug 20 16:29:05 EDT 2009
Hi all,
In case that someone is stuck with the same problem that I had I attached
the code that works for me.
By the way, Can anyone point me to some examples using a web form to enter
and modify attributes store in a PostGIS DB via WFS-T?
Thanks for your help!
//WFS Layer
wfs3 = new OpenLayers.Layer.WFS(
                "Same Water Points",
                "http://localhost:8080/geoserver/wfs",
                {typename: 'cite:water_points'},
                    typename: "water_points",
                    featureNS: "http://www.opengeospatial.net/cite",
                    extractAttributes: false,
                    commitReport: function(str) {
                        OpenLayers.Console.log(str);
		var saveStrategy = new OpenLayers.Strategy.Save({
       callback: function() {
           alert('feature saved');
map.addLayers([wfs3]);
//BUTTONS:
var panel = new OpenLayers.Control.Panel({
                displayClass: "olControlEditingToolbar"
            var draw = new OpenLayers.Control.DrawFeature(
                wfs3, OpenLayers.Handler.Point,
                    handlerOptions: {freehand: false, multi: true},
                    displayClass: "olControlDrawFeaturePoint"
			var modify = new OpenLayers.Control.ModifyFeature(wfs3, {
                title: "Modify Feature",
				displayClass: "olControlModifyFeature"
			 var del = new DeleteFeature(wfs3, {title: "Delete Feature"});
			 var save = new OpenLayers.Control.Button({
                trigger: OpenLayers.Function.bind(wfs3.commit, wfs3),
                displayClass: "olControlEditingToolbar",
				title: "Guardar"
            panel.addControls([
                new OpenLayers.Control.Navigation(),
                save, del, modify, draw
            map.addControl(panel);
Juan Arévalo wrote:
> Hi All,
> I am trying to set up a WFS-T using Geoserver 1.7.6 and PostGres 8.4. I
> have tried with the following code in order to insert new features:
> //WFS LAYER:
> wfs = new OpenLayers.Layer.WFS(
> 				"Cities",
> 				{typename: 'cite:ciudades'},
> 				{featureNS: 'http://www.opengeospatial.net/cite',
> 				srsName:            'EPSG:4326',
> 				version: "1.0.0",
> 				//schema:
> "http://localhost:8080/geoserver/wfs?request=GetFeature&typeName=ciudades&outputformat=text/xml;%20subtype=gml/3.1.1",
> 				//schema:
> "http://localhost:8080/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=cite:ciudades",
> 				schema:
> "http://127.0.0.1:8080/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=cite:ciudades",
> 				extractAttributes: true});
> 				wfs.style = OpenLayers.Util.applyDefaults({strokeColor: "#0000ff"},
>                OpenLayers.Feature.Vector.style["default"]);
> //SAVE BUTTON:
>                 trigger: OpenLayers.Function.bind(wfs.commit, wfs),
>                 displayClass: "olControlSaveFeatures"
> When I click the save button I got this error:
> WFS Transaction: FAILED <?xml version="1.0" ?>
> <ServiceExceptionReport
>    version="1.2.0"
>    xmlns="http://www.opengis.net/ogc"
>    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>    xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
>    <ServiceException>
>       Feature type &apos;featureMember&apos; is not available:
> </ServiceException></ServiceExceptionReport>
> The geoserver log is as follow:
> 2009-08-19 20:57:35,500 ERROR [geoserver.ows] -
> org.geoserver.wfs.WFSTransactionException: Feature type 'featureMember' is
> not available:
> 	at org.geoserver.wfs.Transaction.execute(Transaction.java:222)
> 	at org.geoserver.wfs.Transaction.transaction(Transaction.java:108)
> 	at
> org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:182)
> Does anyone have any idea on how to solve this issue?
> It would be great if you can provide me with some working examples..
> Thanks:)-
> Juan
View this message in context: http://n2.nabble.com/Adding-new-features-WFS-T-PostGIS-tp3474825p3481528.html
