[OpenLayers-Users] Problem with a WFS request
bartvde at osgis.nl
bartvde at osgis.nl
Fri Aug 21 10:36:06 EDT 2009
Hi Arthur,
check out the console tab of Firebug, and make sure XMLHttp requests are
on (check out options on the right in Firebug).
It's because OpenLayers uses POST by default for WFS, so that's why you
don't see any parameters. You will see the POST body though in Firebug.
Best regards,
Bart
> I have no attributes because I use "gml_exclude_items" "all" (for now I
> only need the vectors to display so I thought it was good to minimize
> the request because it's a huge file). But I tried without, with
> "gml_include_items" "all" and with the inclusion of the ID attribute
> only, I can see all these results in the XML flow but still not my
> vectors in OpenLayers.
> I hope I am looking at the right place in Firebug : I am looking at the
> Network tab and I see the WFS request. I am working with two computers :
> one is the WFS server and the other is my working computer, with
> OpenLayers and the webpage (I am working on a local server: MAMP on this
> computer). The two computers are in a local network so I don't think
> there is any problem with this (no proxy).
> So I have two requests in Firebug :
> - one is a request to the local server (MAMP) called
> "http://localhost:8888/test_WFS/test_WFS.php"
> - the other is a request to the second computer :
> "http://IP/cgi-bin/mapserv_5.4.1?map=/var/www/html/WFS_server/test.map"
> Is this normal that there is no options after the address of the mapfile
> ? When I look at the URL request I did for testing I see the SERVICE,
> TYPENAME, BBOX, etc. Also there is no data download.
> Best regards,
> Arthur
> bartvde at osgis.nl a écrit :
>> Your GML looks okay to me. You don't have any attributes (next to the
>> geometry), but that should be no problem.
>> Can you see the request go off with Firebug at all when adding the
>> vector
>> layer to your map? Are you using a proxy in between or is the traffic
>> local?
>> Best regards,
>> Bart
