[OpenLayers-Users] Overriding map style causing major drift
Christopher Dale chrelad at gmail.com
Fri Aug 21 12:53:59 EDT 2009
Heya Everyone,
I found an example on OpenLayer's site that shows another way of
accessing and modifying properties of layers.
http://openlayers.org/dev/examples/modify-feature.html
This is the line that worked for me:
OpenLayers.Feature.Vector.style['default']['strokeWidth'] = '2';
Thanks everyone and thanks to team OpenLayers for making something awesome,
Chrelad
On Fri, Aug 21, 2009 at 8:58 AM, Christopher Dale<chrelad at gmail.com> wrote:
> Hi everyone,
> This is my first post to the list, so let me know if I'm missing
> anything or could improve on my posts.
> I have an OpenLayers map with two layers. The first layer contains
> virtual earth base tiles (street view) and the second is a vector
> layer I use in conjunction with the editing toolbar. The map's
> projection is spherical mercator and everything seems to be working
> great. However, when I tried to change the weight and color of the
> polylines created by the editing toolbar, everytime I would click to
> add a point to the polyline, it would be way off (to the right). The
> code I used to add the style is below:
> var layer_style = OpenLayers.Util.extend({},
> OpenLayers.Feature.Vector.style['default']);
> layer_style.strokeColor = 'black';
> vlayer = new OpenLayers.Layer.Vector('Editable', {style: layer_style});
> It may help to know that vlayer (vector layer) from the aforementioned
> code is created with sphericalMercator set to true.
> I used this website as a reference for styling layers:
> http://openlayers.org/dev/examples/vector-features.html
> Is this the correct way to go about styling vector features? Is there
> a different way you have to handle features created using the editing
> toolbar? Any input would be appreciated :)
> Thanks everyone and great list,
> Chrelad
