[OpenLayers-Users] problem selecting vector features with labels -
Potential IE bug
Michael Anderson
mike at spatialit.com
Fri Aug 21 15:55:30 EDT 2009
I added labels to a vector layer and hooked up a ModifyFeature control.
Everything works fine in FireFox. In IE 7 and 8 when you try to click on a
feature to select it, and you click over the label, nothing happens. If the
feature is selected and you click over the label it is unselected as it
should be. So the problem is only with selecting. There is an example here:
http://128.118.7.3/testing/testlabel.html
Thanks.
Mike
