[OpenLayers-Users] How to make a drag and drop for markers?
Alexandre Dube
adube at mapgears.com
Mon Aug 24 08:11:17 EDT 2009
Jimmy Aumard wrote:
> Hello, thanks for answers,
> My problème is I use markers and I put/update attributes on each in my
> database. I don't know how put or update attributes with vector layer
> (if you have an example I take it :D).
You need a server that supports transactions :
- GeoServer
- TinyOWS
see the example :
http://openlayers.org/dev/examples/wfs-protocol-transactions.html
- FeatureServer (uses MapFish protocol)
see a demo : http://dev4.mapgears.com/bdga-fs/
The FS demo also shows a way to edit feature's attributes.
> I use vector layer for polygon with DragFeature. I know this solution
> but points representation is a point an I use icon, It's possible to
> put an icon to a point with a vector layer?
Yes. Look at the following example and search the source for the
externalGraphic property.
http://openlayers.org/dev/examples/styles-unique.html
Regards,
Alexandre
> Sorry for my english :s
> Cheers
> Jim
> 2009/8/24 Eric Lemoine <eric.lemoine at camptocamp.com
> <mailto:eric.lemoine at camptocamp.com>>
> On Friday, August 21, 2009, Alexandre Dube <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
> > Hi,
> > One way to accomplish this is to use a Vector layer instead of a
> > Marker layer and use a ModifyFeature control do move your points
> > (markers) around.
> The DragFeature control may be of interest as well.
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
Alexandre Dubé
Mapgears
www.mapgears.com
