[OpenLayers-Users] Get drawn feature from map and add it to a layer.
Ambran
amit.bracha.andersen at atkinsglobal.com
Mon Aug 24 09:29:36 EDT 2009
Hi
This should be a simple question.
I'm working on limiting a path to one single line. What I did was to fire a
function on "Point" event. A global var is counting the points created. In
this function when the global var is 2, I have an alert which pops up fine.
What I want to do instead of the alert, is add the drawn line to a layer.
Afterwords I deactivate the draw control, and that's it.
This is my DrawFeature control:
line: new OpenLayers.Control.DrawFeature(vectors, OpenLayers.Handler.Path,
{callbacks: { "point": this.TwoClickPath.bind(this) }}),
And this is the function that is being fired:
TwoClickPath: function(e) {
this.TwoClickPathCount++;
if (this.TwoClickPathCount == 2) {
Here I want to add the drawn line to a layer
// alert(""); fires ok
controls.line.deactivate();
this.TwoClickPathCount = 0;
How do I add the drawn line to a layer without double-clicking?
Thanks in advance
Amit
View this message in context: http://n2.nabble.com/Get-drawn-feature-from-map-and-add-it-to-a-layer-tp3503203p3503203.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090824/5266a3c6/attachment.html
