[OpenLayers-Users] Problem with a WFS request
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Mon Aug 24 14:51:07 EDT 2009
Arthur,
did you setup the Python proxy in between?
http://faq.openlayers.org/proxyhost/all/
Best regards,
Bart
Arthur Delorme wrote:
> Hi Bart,
> When the webpage is loading or when I play with the layer switcher, I
> don't have anything displaying in the console tab (XMLhttp is on). So
> I made the test with all the files on the second computer (the one
> with mapserver) and it works !
> Do you have any idea for this network problem ? I can work on the
> second computer also so it's not really a problem but I would like to
> understand what's happening. Maybe it's just because I am working with
> a local server, not a true one ?
> Thank you very much for your help and patience !
> Best regards,
> Arthur
> bartvde at osgis.nl a écrit :
>> Hi Arthur,
>> check out the console tab of Firebug, and make sure XMLHttp requests are
>> on (check out options on the right in Firebug).
>> It's because OpenLayers uses POST by default for WFS, so that's why you
>> don't see any parameters. You will see the POST body though in Firebug.
>> Best regards,
>> Bart
>>> I have no attributes because I use "gml_exclude_items" "all" (for now I
>>> only need the vectors to display so I thought it was good to minimize
>>> the request because it's a huge file). But I tried without, with
>>> "gml_include_items" "all" and with the inclusion of the ID attribute
>>> only, I can see all these results in the XML flow but still not my
>>> vectors in OpenLayers.
>>> I hope I am looking at the right place in Firebug : I am looking at the
>>> Network tab and I see the WFS request. I am working with two
>>> computers :
>>> one is the WFS server and the other is my working computer, with
>>> OpenLayers and the webpage (I am working on a local server: MAMP on
>>> this
>>> computer). The two computers are in a local network so I don't think
>>> there is any problem with this (no proxy).
>>> So I have two requests in Firebug :
>>> - one is a request to the local server (MAMP) called
>>> "http://localhost:8888/test_WFS/test_WFS.php"
>>> - the other is a request to the second computer :
>>> "http://IP/cgi-bin/mapserv_5.4.1?map=/var/www/html/WFS_server/test.map"
>>> Is this normal that there is no options after the address of the
>>> mapfile
>>> ? When I look at the URL request I did for testing I see the SERVICE,
>>> TYPENAME, BBOX, etc. Also there is no data download.
>>> Best regards,
>>> Arthur
>>>> Your GML looks okay to me. You don't have any attributes (next to the
>>>> geometry), but that should be no problem.
>>>> Can you see the request go off with Firebug at all when adding the
>>>> vector
>>>> layer to your map? Are you using a proxy in between or is the traffic
>>>> local?
>>>> Best regards,
>>>> Bart
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
