[OpenLayers-Users] DragPan and SelectControl on Vector layer
Jeremy Husmann
Jeremy.Husmann at critchlow.co.nz
Thu Aug 27 04:16:06 EDT 2009
Hello everyone,
Unsure if this is possible or not so I thought I might put the question
out there incase someone had done this before.
If you are adding a vector layer to a basemap you can pan across any
polygons if you are zoomed right in on them. Bu as soon as you add a
selectControl to the layer you loose this capability to pan. i.e. a
click and hold wont pan but a full click will still select.
Is there any way to accomplish both controls at once on a vector layer?
I have tried adding the 'DragPan' control directly to the Vector layer
but no luck.
Any ideas?
Thanks guys,
Jeremy
us immediately.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090827/79c07365/attachment.html
