[OpenLayers-Users] Cluster strategy not working
Max Stephan
x.zam at gmx.net
Fri Aug 28 06:27:41 EDT 2009
Hi everybody,
I`m having problems getting the cluster strategy to work. It simply makes no
difference in terms of appearance if I add it to the VectorLayer or not.
This is my code for the layer:
vectorLayer = new OpenLayers.Layer.Vector("Vektorlayer",{
strategies: [
new OpenLayers.Strategy.Cluster({distance:20})
styleMap: vectorStyle2, maxResolution: 19});
The reason why I want to add it is that I have 480 Features alltogether on
my map and even when zooming into some areas there are still around 150
features left in the bbox causing InternetExplorer to slow down (don´t know
if it´s the same case with Firefox, but I gotta use IE to use
ADODB-Connection to an Access Database in the Intranet).
Those features are created and added step by step with an addVector-method I
have implemented that reads out the coordinates and attributes of the
database for a single feature and then jumps to the next entry and repeats
the procedure till all features have been added.
greets and thx in advance
Max Stephan
View this message in context: http://n2.nabble.com/Cluster-strategy-not-working-tp3533851p3533851.html
