[OpenLayers-Users] Cluster strategy not working
Shawn Oatley shawn at niagarafalls.ca
Fri Aug 28 09:26:45 EDT 2009
I don't have any input regarding the code, but I have worked with IE 8.
Not sure if that is an option, but if it is, they have a powerful script
debugger that allows you to step through the code also.
Shawn
>>> Max Stephan <x.zam at gmx.net> 08/28/09 8:24 AM >>>
Hi Jerome,
I´d be very happy if I could use Firebug in this case (very nice tool
for
debugging and for tracking the DOM in my opinion) but as I mentioned
above:
I´m using an ActiveX-Control for reading out the Access-Database and for
sending further requests to it. And this method is only possible in
Internet
Explorer for which I haven´t found such a powerful debugging tool as
firebug
(firebug lite wasn´t useful).
Ok, now here´s the loop, which is adding the vector-features to my
vector-layer:
for (var i=0; i<mestArray.length; i++){
    addVector(vectorLayer, mestArray[i][1], mestArray[i][0]);
The first parameter is the target-layer, the second is a lonlat-object
and
the third is an attribute for the features.
And here´s the addVector-function:
function addVector(layer, lonlat, mestId){
   var geometryObjekt = new
OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);
   var vectorObjekt = new OpenLayers.Feature.Vector(geometryObjekt);
   vectorObjekt.attributes.mest = mestId;
   layer.addFeatures([vectorObjekt]);
And concerning your english: No need to be worried. I´m understanding
everything.
Thx in advance
Max Stephan
Jerome Freyre wrote:
> Can you also show us your method that parse and add the feature to the
> layer?
> I think another good way to explore is to use firefox and firebug.
> With firebug, you can add breakpoints and the go step-by-step...
> Whith that, you should put a breakpoint into your method that parse
> and add features to layer and another one into the cluster strategy
> (Think to not use the OpenLayers minimised but the complete source) to
> see if software run into the class correctly...
> Hope my english is quite understandable.... :)
> Jérome
> Le 28 août 09 à 14:01, Max Stephan (via Nabble) a écrit :
>> Hi Jerome,
>> thanks for your reply. I already tried that but it causes an error
>> ("this.layer.events" is null or no object) and the map content isn
>> ´t shown.
>> Any other ideas?
>> Greets,
>> Max Stephan
>> Hi Max,
>> Personnally, when I use Cluster Strategy, I create separatly the
>> strategy and the I activate it.
>> 			var strat = new
OpenLayers.Strategy.Cluster({distance:20});
>> 			vectorLayer = new
OpenLayers.Layer.Vector("Vektorlayer",{
>> 			strategies: [
>> 				strategy
>> 			styleMap: vectorStyle2, maxResolution: 19});
>> 			strat.activate();
>> Hope it will be usefull....
>> Sincerly,
>> Jérome
>> Max Stephan wrote:
>> Hi everybody,
>> I`m having problems getting the cluster strategy to work. It simply
>> makes no difference in terms of appearance if I add it to the
>> VectorLayer or not.
>> This is my code for the layer:
>> 		vectorLayer = new
>> 			strategies: [
>> 				new
>> The reason why I want to add it is that I have 480 Features
>> alltogether on my map and even when zooming into some areas there
>> are still around 150 features left in the bbox causing
>> InternetExplorer to slow down (don´t know if it´s the same case
>> with Firefox, but I gotta use IE to use ADODB-Connection to an
>> Access Database in the Intranet).
>> Those features are created and added step by step with an addVector-
>> method I have implemented that reads out the coordinates and
>> attributes of the database for a single feature and then jumps to
>> the next entry and repeats the procedure till all features have been
>> added.
>> greets and thx in advance
>> Max Stephan
>> View message @
http://n2.nabble.com/Cluster-strategy-not-working-tp3533851p3534202.html
>> To unsubscribe from Re: Cluster strategy not working, click here.
View this message in context:
http://n2.nabble.com/Cluster-strategy-not-working-tp3533851p3534315.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
