[OpenLayers-Users] Save Vector drawings in PostGIS
Alexandre Dube adube at mapgears.com
Fri Aug 28 13:47:58 EDT 2009
Here's an old demo using OpenLayers + TinyOWS for WFS-T. This might give
you some ideas.
http://dev4.mapgears.com/bdga/bdgaWFS-T.html
Alexandre
Paul Spencer wrote:
> Try using tinyows, it is a lightweight c-based cgi that implements WFS
> with transaction support and is backed by a postgres/postgis
> database.  The WFS protocol in OpenLayers seems to work perfectly with
> it, use the Save strategy to ensure every edit gets saved to the db
> and you can use mapserver to draw maps with features from the db.
> Cheers
> Paul
> On 2009-08-28, at 11:49 AM, AlessioDL wrote:
>> Hi,
>> I'm looking for a strategy to use OL as an editor to populate a
>> polygon
>> postgis layer.
>> I can't use WFS-T because I have to work with UMN-Mapserver that
>> doesn't
>> support this specification.
>> What I would like to do is this:
>> (1) use the drawing tools to create my vector features on the map
>> (2) capture the WKT string for these drawings in a form field
>> (3) send an insert query to postgis via PHP
>> The (1) and (3) are ok for me, but I need some help with the (2).
>> Can you give me some suggestions?
>> Is my "strategy" correct in your opinion?
>> TIA, alessio
>> View this message in context: http://n2.nabble.com/Save-Vector-drawings-in-PostGIS-tp3535558p3535558.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Alexandre Dubé
Mapgears
www.mapgears.com
