[OpenLayers-Users] Performance
Ivan Grcic
igrcic at gmail.com
Mon Aug 31 03:24:02 EDT 2009
HI, this is not so much related to OpenLayers, but to server components: db
and mapserver that generate image, so you should try asking there (have you
made spatial indexes in your database? )
cheers
On Mon, Aug 31, 2009 at 7:31 AM, Rahn Hanno (rahn) <rahn at zhaw.ch> wrote:
> Hello list,
> I have another question. I have a solution with 4 different maps. In this
> maps there will always be the same geometries (polygons) but the polygons
> will style with a sld file in different ways.
> Now my question. My solution is not very fast. Are there possibilities for
> upgrade the performance of the maps? I think you can do some things to get a
> higher performance, but I don’t know what someone has to do for this. Are
> there some rules or tipps from you to get a better performance?
> My data comes from a postgreSQL/postgis database. You can see an example
> here:
> http://webgis.hsw.ch/GINES/Start.php
> Is it better to use tiles for this?
> Greetings
> Hanno Rahn
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche
> Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090831/cbbbc324/attachment.html
