[OpenLayers-Users] Fw: vector layers don't display in internetexplore 8.0.6001 anymore
stephane.poirier at usherbrooke.ca stephane.poirier at usherbrooke.ca
Mon Aug 31 11:44:18 EDT 2009
Nop Chris, the standard, by the book, vector layers demos do not work in my
current IE80 install. I had this problem ever since the version 2.8rc2, but
was working around using IE80 compatibility view to draw have everything
draw perfectly. I also saw this problem occur when developing with 2.7 under
IE70. I lost the vector layer drawing at some point (this for any demos of
the large openlayers standard demos set - involving any vector layer, even
selection tool does not draw). My IE70 problem disaper when I updated with
IE80 provided using compatibility view.
It is like if I should fix my IE install, but don`t know what to reset. In
the recent days, with some ms-auto-update, the compatibility view mechanism
is different, and does not seems to work anymore on my system. It is always
using the new standard IE80 drawing and therefore I lost my capabilities of
drawing vector layers.
I have not reproduced this bug on other machines, but then again, I am
pretty much always on my same developer machine (an XP Pro installed version
5.1.2600 service pack 3 Nu 2600 in french). My dxdiag directx diagnostic
currently shows an non-optimal version of the d3d9d.dll (version
9.18.0944.0000 as opposed to my non-debug versions d3d9.dll and others being
mostly stamped 5.03.2600.5512). I will also test under this sme computer`s
WIN2K3 IE70 and IE80 install and let you know soon. But, I would really
appreciate to find the fix for this WINXP PRO french install.
SP.
> From: "Christopher Schmidt" <crschmidt at metacarta.com>
> Sent: Monday, August 31, 2009 10:33 AM
> To: <stephane.poirier at usherbrooke.ca>
> Cc: <users at openlayers.org>
> Subject: Re: [OpenLayers-Users] vector layers don't display in
>> On Sun, Aug 30, 2009 at 11:02:22PM -0400, stephane.poirier at usherbrooke.ca
>> wrote:
>>> Hi All,
>>> My vector layers do display fine in Firefox, Chrome, Safari but don't
>>> display at all in IE 8.0.6001. I was using IE 8.0 compatibility view to
>>> have proper vector layer display until recently. But now, Ie 8.0
>>> compatibility view does not seems to work or fix that issue anymore.
>>> Should I write specific code for IE 8.0? Or, is there a patch for IE
>>> 8.0?
>> Do the OpenLayers examples
>> (http://openlayers.org/dev/examples/vector-features.html) work in IE 8?
>> If they do, then you should explore why they don't work in your
>> application.
>> If they don't, I'd be interested in hearing about it.
>> Regards,
>> Christopher Schmidt
>> MetaCarta
