[OpenLayers-Users] [Geoserver-users] Get Feature Info On Google
Map Overlay
Andrea Aime
aaime at opengeo.org
Mon Feb 2 03:03:50 EST 2009
Bradley McLain ha scritto:
> Hi all,
> What i have so far is a map that has a Google map satellite as a base
> layer and a custom WMS layer over the top.
> When i create a map that only has the WMS layer (in projection
> EPSG:4326) it works fine and i can do queries on all the feature
> information as the tutorial shown here:
> http://openlayers.org/dev/examples/getfeatureinfo.html
> However if i try and put this into a google map (projection EPSG:900913)
> and overlay the WMS i get the following error:
> org.geoserver.platform.ServiceException: org.xml.sax.SAXParseException:
> Content is not allowed in prolog. org.xml.sax.SAXParseException: Content
> is not allowed in prolog. Content is not allowed in prolog.
Mumble, I've seen that kind of error in a GetMap request only if you're
adding a SLD_BODY or a FILTER parameter to the request, and their
contents is invalid.
Can you go into the config/server panel and enable "verbose exceptions"
and then grab the full service exception (with the full stack trace that
would tell us where the error originated from)?
Cheers
Andrea
Andrea Aime
OpenGeo - http://opengeo.org
Expert service straight from the developers.
