[OpenLayers-Users] combining handlers, or hover + select
Jesse V Griffis
jvgriffis at gmail.com
Tue Feb 3 09:02:12 EST 2009
Thanks Eric,
I wasn't sure if dumping a bunch of code to the list would be useful.
Essentially, I just copied the Hover Control from the example page
(http://openlayers.org/dev/examples/hover-handler.html) and tried to
copy the stuff from the SelectFeature Control (in the source).
Testing it, I know the hover/pause part of this is working, but I
can't figure out how to apply the selection piece. Please don't laugh
too hard:
OpenLayers.Control.Hover = OpenLayers.Class(OpenLayers.Control,
layer: null,
isPaused: false,
defaultHandlerOptions: {
'delay': 1000,
'pixelTolerance': 1,
'stopMove': false
initialize: function(layer, options)
this.layer = layer;
this.handlerOptions = OpenLayers.Util.extend(
{}, this.defaultHandlerOptions
OpenLayers.Control.prototype.initialize.apply(
this, arguments
this.handlers = {
feature: new OpenLayers.Handler.Feature(
this, this.layer, { 'over': this.over}, {}
hover: new OpenLayers.Handler.Hover( this,
{'pause': this.onPause, 'move': this.onMove}, this.handlerOptions
draw: function() {
return false;
activate: function() {
this.handlers.feature.activate();
this.handlers.hover.activate();
deactivate: function() {
this.handlers.feature.deactivate();
this.handlers.hover.deactivate();
onPause: function(evt) {
this.isPaused = true;
onMove: function(evt) {
this.isPaused = false;
over: function(feature) {
if ( this.isPaused)
console.log(feature);
On Tue, Feb 3, 2009 at 1:03 AM, Eric Lemoine <eric.c2c at gmail.com> wrote:
> Hi
> It is hard to help you without seeing actual code. Feel free to come
> back to the list with your code.
> Cheers,
> Eric
> 2009/2/3, Jesse V Griffis <jvgriffis at gmail.com>:
>> Greetings,
>> I can successfully use the hover examples to create a "Hover" Control
>> that uses the Hover handler to pop up info when you pause in one place
>> long enough. I can successfully use the SelectFeature Control to
>> click and display info about Vectors.
>> What I can't figure out is how to combine them, and make a pause on
>> the map select the feature under the mouse. It's frustrating to get
>> so close and yet be so far.
>> Does anyone have an example of this?
>> Thanks,
>> Jesse
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
