[OpenLayers-Users] Where Do I Find A List of Available
Hashtable Options?
Bill Thoen
bthoen at gisnet.com
Fri Jan 2 10:04:23 EST 2009
Thanks for the info, Christopher.
However, the syntax you list for overriding the MapServer map file
parameter doesn't work. If you (or anyone else) knows how I can
override the layer color to yellow (255 255 0) in OpenLayers from a map
file that looks like the following, I'd appreciate knowing what the
trick is.
LAYER
NAME "states"
TYPE POLYGON
DATA states
CLASS
NAME "US States"
STYLE
OUTLINECOLOR 100 100 100
COLOR 255 255 192
END
END
PROJECTION
"init=epsg:32614" # UTM Zone 14 N WGS84
END
STATUS DEFAULT
END
Christopher Schmidt wrote:
> On Thu, Jan 01, 2009 at 04:08:24PM -0700, Bill Thoen wrote:
>> In several places in the OpenLayers Constructor functions there is a
>> parameter that is an object consisting of a "Hashtable of extra
>> options...", but I can't find a list of what those choices might be. For
>> example, the fourth parameter for OpenLayers. Layer. MapServer() is such
>> an object. What are the available tags that can be used here and where
>> do I find out what these are? Are they the parameters from a map file,
>> like LAYER.CLASS.STYLE.COLOR: "255 255 0" or something like that?
> Options override the 'properties' of the layer: anything that is listed
> as a property of the Layer in the API documentation can be overridden
> via the options hash.
> What you want is another parameter (the third param): something like
> {'layers': 'a, b', 'layers[a].class.style.color': 'red'}. The third
> parameter is serialized and sent directly to the server with *no*
> intervention on the part of OpenLayers (except in WMS, where keys are
> uppercased); this means that you simply need to figure out the right
> parameter to send to MapServer and include it as a key/value pair in the
> parameters hash.
> Regards,
