[OpenLayers-Users] Event registration in activate function
Alexandre Dube
adube at mapgears.com
Wed Jan 7 16:02:22 EST 2009
Dear list,
I'm writing my own Control and I need to register some events. Doing
so in the initialize function isn't good because some objects are not
created yet ( like the map object ). So I thought I could register them
in the activate() func and unregister them in the deactivate() func.
So far it was ok to do so, but now I'm facing a problem. I need to
register events that, when triggered, deactivate the control, and other
events that, when triggered, reactivate the control. It's a control
that can contain multiple layers that come from the same source but have
been normalized to render faster, so the user sees no difference when
zooming. The control change the opacity of a layer when the mouse is
over it and because the features generated come from different sources,
I need to deactivate the control while I'm zooming ( deactivate on
loadstart, activate on loadend ). This looks like this :
// inside the activate function()
for (var key in this.layers){
this.layers[key].events.register(
"loadstart", this, this.deactivate);
"loadend", this, this.activate);
So basically I should unregister them in the deactivate function(),
right ? The problem is : if I deactivate the control, it will
unregister the loadend event so it will not be reactivated in the end.
Is there an other place I should register my events to avoid that
behavior ? I see in some other control registration on events in a
draw() function. Could I do something similar ?
Alexandre Dubé
Mapgears
www.mapgears.com
