[OpenLayers-Users] Does anyone have an example of using the measure
control in a toolbar?
Semantica
jvanulde at nrcan.gc.ca
Tue Jan 13 11:45:58 EST 2009
I am having issues with this. For some reason, my control won't
activate/deactivate when the button is clicked. Here are a couple of
snippets:
var optionsLine = {
handlerOptions: {
style: "default", // this forces default render intent
layerOptions: {styleMap: styleMap},
persist: true
displayClass: 'olControlMeasureDistance'
var optionsPolygon = {
handlerOptions: {
persist: true
displayClass: 'olControlMeasureArea'
measureControls = {
line: new OpenLayers.Control.Measure(OpenLayers.Handler.Path,
optionsLine),
polygon: new OpenLayers.Control.Measure(OpenLayers.Handler.Polygon,
optionsPolygon)
// add the measure controls to the map
var control;
for(var key in measureControls) {
control = measureControls[key];
control.events.on({
"measure": handleMeasurements,
"measurepartial": handleMeasurements
panel.addControls([measureControls.line, measureControls.polygon]);
// add the panel to the map
map.addControl(panel);
Any ideas on what the problem might be?
Thank you in advance!
View this message in context: http://n2.nabble.com/Does-anyone-have-an-example-of-using-the-measure-control-in-a-toolbar--tp2152008p2152008.html
