[OpenLayers-Users] Drag feature control slow in IE
Andre Pereira de Matos andre.matos at co.sapo.pt
Tue Jan 13 12:56:01 EST 2009
Yes, the same issue occurres when you used this example on IE.
Is it a bug? Any plans/suggestions to fix it?
Regards,
André Matos
http://maps.sapo.pt
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] On Behalf Of Frédéric Junod
Sent: terça-feira, 13 de Janeiro de 2009 15:03
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] Drag feature control slow in IE
Do you have the same issue with
http://openlayers.org/dev/examples/drag-feature.html ?
Your code looks reasonable to me ...
fredj
Le Tue, 13 Jan 2009 14:43:46 +0000,
Andre Pereira de Matos <andre.matos at co.sapo.pt> a écrit :
> Hi list,
> I have done an example with a draggable feature (with DragFeatureControl). In
> Firefox, Google Chrome works fine... But when I drag it on IE it is very
> slow...
> The code used is:
> markersLayer = new OpenLayers.Layer.Vector("Markers",
>        projection:
> new OpenLayers.Projection("EPSG:4326"), styleMap: new OpenLayers.StyleMap({
>        externalGraphic:
> "http://openlayers.org/dev/img/marker-gold.png", backgroundGraphic:
> "http://openlayers.org/dev/examples/marker_shadow.png", graphicYOffset: -20,
>        backgroundXOffset:
> 0, backgroundYOffset: -17,
>        pointRadius:
> 10 })
>                 map.addLayer(markersLayer);
>                 feature1 = new OpenLayers.Feature.Vector(new
> OpenLayers.Geometry.Point(-1904105.3415234375, 4392319.753066596)); feature2
> OpenLayers.Geometry.Point(-1504105.3415234375, 4392319.753066596));
> markersLayer.addFeatures([feature1, feature2]);
>                 var ccontrol = new
> OpenLayers.Control.DragFeature(markersLayer); map.addControl(ccontrol);
>                 ccontrol.activate();
> Any suggestions? Is it a bug? Will it be fixed?
> Regards,
> André Matos
> http://maps.sapo.pt
Frédéric Junod
Camptocamp SA
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
