[OpenLayers-Users] OL 2.7 measure control questions
Tim Schaub
tschaub at opengeo.org
Wed Jan 14 19:12:00 EST 2009
Zer wrote:
> Dear list,
> Is there a way to change to mouse pointer to a hair cross when using then
> measure control?
control.events.on({
activate: function() {
map.div.style.cursor = "crosshair";
deactivate: function() {
map.div.style.cursor = "default";
Of course you'll be better off if you use methods like:
OpenLayers.Element.addClass(map.div, "cursor_cross");
and
OpenLayers.Element.removeClass(map.div, "cursor_cross");
And then load up a stylesheet that has something like
.cursor_cross {
cursor: crosshair;
> Is there a way to always present the measured distance in meters? The
> distance shows in km as soon as a distance longer than 1000m is measured.
var control = new OpenLayers.Control.Measure(OpenLayers.Handler.Path, {
displaySystemUnits: {metric: ["m"]}
This property (displaySystemUnits) is not marked as part of the API - so
you may have to change your app if it changes (don't imagine it will in
2.x).
Tim
> Thanks,
> Z
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
