[OpenLayers-Users] Hover control sample (share)
Alexandre Dube
adube at mapgears.com
Thu Jan 15 13:29:50 EST 2009
Thanks Eric for your comments,
As you said, it was not too hard to build. My first thought was that
a SelectFeature control actually "select" the feature ( change its
renderIntent to "select" ) so a selected feature gets drawn with the
"select" style. That was not what I had in mind at first. I wanted to
have an other color for that, or I could say that I actually wanted to
know when I could click a feature to select it by changing its color first.
I would be glad to create a ticket for this feature. Do you think
"Hover" is a good name for what this control does ? ( changing the style
of features when the mouse is over it, can also display a popup at the
same time with all the features attributes/values )
Thanks again,
Alexandre
Eric Lemoine wrote:
> Thanks for sharing your code Alexandre.
> I thought about a Feature control in the past. That control would use
> a Feature handler internally and would be configured to work either in
> hover or click mode, just like the SelectFeature control. But, as
> yours, it wouldn't select features, but just trigger events when
> features are hovered or clicked. To avoid code duplication I also
> imagined that the SelectFeature control could be based on that control
> instead of relying directly on the Feature handler.
> But I had the same reasoning as you: why bother? Building a custom
> Feature handler-based control is easy enough...
> But, actually, there are so many people needing that thing that it may
> be valuable to have it in trunk.
> Cheers,
> Eric
> 2009/1/15, Alexandre Dube <adube at mapgears.com>:
>> Hi list,
>> I just want to share a sample of Handler.Hover usage I do. The result
>> is a Control.Hover I use to change the style of features hover the mouse
>> without selecting them and display a popup at the same time. You could
>> also register events on "hoverfeatureset" and "hoverfeaturereset" to do
>> more stuff if you want.
>> See the example :
>> http://dev.openlayers.org/sandbox/adube/openlayers/examples/hover-control.html
>> See the code :
>> http://dev.openlayers.org/sandbox/adube/openlayers/lib/OpenLayers/Control/Hover.js
>> At first I wanted it to be a new OpenLayers feature, but then I
>> thought that Handlers were created for the purpose of customizing our
>> own controls depending of what our needs are. So this Hover control is
>> one of many possible usage of Handlers, so IMHO it's not useful to make
>> it a new feature. Sharing it is enough.
>> Comments are welcomed,
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Alexandre Dubé
Mapgears
www.mapgears.com
