[OpenLayers-Users] GML and GetFeatureInfo
RFeagin
ryan.feagin at PEACHTREEGEOGRAPHICS.COM
Thu Jan 15 22:30:00 EST 2009
Andrew-
I'm running into the same problem. Did you ever find another way to get it
working? If not, then would you mind sharing your xsl stylesheet?
Thanks
Spencer, Andrew wrote:
>>mpriour wrote:
>>> For each attribute node get the attribute from the 'ref' attribute
> and the
>>> value from the innerText
>>I actually meant the innerHTML property of that node or the value of
> its
>>childText node. not the IE only innerText property.
>>Matt
> Thank you Matt, your response is greatly appreciated. I couldn't get it
> to work by applying the MapInfo namespace, but it should do shouldn't
> it, so I suspect I was doing something else wrong. I solved the
> immediate problem by using an xsl stylesheet, which kind of gets me off
> the hook at the moment! It's good to know where we are at though.
> Thanks again
> Andrew
> If this email has been received in error, please delete all copies
> and inform the National Native Title Tribunal by return email or
> telephone 1800 640 501.
> The Tribunal does not warrant that its email is virus free.
> All emails sent to the Tribunal are filtered for viruses and
> inappropriate content. Thus your email may not reach the person to
> whom it is addressed. Seek confirmation of receipt of your email if you
> consider the email important.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/GML-and-GetFeatureInfo-tp1831488p2166382.html
