[OpenLayers-Users] Generate Numbered Icons on the Fly
Arnie Shore ashore3 at verizon.net
Fri Jan 16 23:54:05 EST 2009
Folks, for those of you working in PHP-land and can use numbered icons,
the attached script may be of interest.
I'm using this for a GMaps-based (for now) Open Source dispatch system
that uses numbered icons rather extensively.  Until recently, I've
packaged the script with 400+ numbered and colored icons to accommodate
busier sites.  While that's worked, it's admittedly rather clumsy and
really bloats the installation zipfile.
The attached script generates numbered - or lettered - icons on the
fly.  It assumes eight colors and the usual teardrop shapes.  It ain't
hugely complex - to say the least - but mebbe useful, although you'll
need some PHP chops to adapt it to yr own use.
(See the application at http://www.saefern.org/tickets/ - guest login
available.)
Arnie Shore
Annapolis, MD
Type: application/x-php
Desc: not available
Url : http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090116/9385d5a3/gen_icon.bin
