[OpenLayers-Users] MapGuide overlay session ID requirements
Zac Spitzer zac.spitzer at gmail.com
Sat Jan 17 10:23:17 EST 2009
if it's tiled it's cached, if it's dynamic with a session the config is cached
so it's faster... wms in mg is more 'stateless' i think so there's
more overhead...
as mg needs to load everything each time per wms tile
z
On Sat, Jan 17, 2009 at 11:01 PM, gingerbbm <stuart.jones at jacobs.com> wrote:
> In a rudimentary test I set up OpenLayers with a WMS layer and a MapGuide
> layer pointing to the same map on the MapGuide server that returns points
> from an Oracle database, and the MapGuide layer loads noticeably faster. If
> the MapGuide server caches this data too then that's even better.
> I have another map on the server that's built from WFS layers from a remote
> location. Using the OpenLayers WMS layer class to access these puts a real
> strain on the MapGuide server and in fact we get all sorts of memory
> problems. If I use the MapGuide layer class to access these, will MapGuide
> cache them?
> I suppose ideally we should access the remote WFS layers directly from
> OpenLayers, but that's not possible for security reasons.
> View this message in context: http://n2.nabble.com/MapGuide-overlay-session-ID-requirements-tp2169448p2172812.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
