[OpenLayers-Users] Problem whit "Same-origin policy"
Pablo Díaz
inspdr00 at gmail.com
Mon Jan 19 13:38:39 EST 2009
Thanks so much!!
But, how do I do that?
I've tomcat rus on port 80, geoserver runs on port 8080 and I runs most
of GETs with OpenLayers (I draw polygons, I put the result into a
textarea, I select polygons) but I can't use GetFeatureInfo with
diferent port.
Thank you again!!.
El lun, 19-01-2009 a las 12:08 -0500, Amos Hayes escribió:
> It's a browser security feature. You'll need to set up a reverse
> proxy. If you run Apache on port 80 and use its reverse proxy
> features, you can put your various services under a port 80 path.
> Amos Hayes
> Geomatics and Cartographic Research Centre
> Carleton University
> ahayes at gcrc.carleton.ca
> +1.613.520.2600x8179
> On 19-Jan-09, at 11:56 AM, Pablo Díaz wrote:
> > Hello list,
> > Well, excuse my English.
> > I've an application with OpenLayers, Tomcat an Geoserver.
> > When I try to connect my application in tomcat with vector layers in
> > Geoserver, I've no problem if geoserver runs in port 80 (the same as
> > tomcat), but when I try to connect when geoserver runs in port 8080 I
> > get the next exception by firebug:
> > Access to restricted URI denied" code: "1012
> > http://localhost/VisorOL/javascript/OpenLayers-2.7/OpenLayers.js
> > Line 513
> > Seaching, I found that this error means that I broke the "Same-origin
> > policy", but I don't know how arrange this problem.
> > I need geoserver runs in port 8080 not in port 80.
> > Some idea?.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
