[OpenLayers-Users] OL 2.7 measure control questions
Tim Schaub
tschaub at opengeo.org
Tue Jan 20 01:35:09 EST 2009
Hey-
Zer wrote:
> Thanks!
> Cross hair works great!
> But the meter/kilometer thing is still a problem. Even though i use
> 'displaySystemUnits: {metric: ["m"]}', the control gives the result in km if
> lenght is more than 1000 meters.
Can you post a (relevant) bit of your application code?
Adding the following property to the options (second argument) of the
measure control constructor should do the trick:
Tim
> -Z
> Tim Schaub wrote:
>> Zer wrote:
>>> Dear list,
>>> Is there a way to change to mouse pointer to a hair cross when using then
>>> measure control?
>> control.events.on({
>> activate: function() {
>> map.div.style.cursor = "crosshair";
>> deactivate: function() {
>> map.div.style.cursor = "default";
>> Of course you'll be better off if you use methods like:
>> OpenLayers.Element.addClass(map.div, "cursor_cross");
>> and
>> OpenLayers.Element.removeClass(map.div, "cursor_cross");
>> And then load up a stylesheet that has something like
>> .cursor_cross {
>> cursor: crosshair;
>>> Is there a way to always present the measured distance in meters? The
>>> distance shows in km as soon as a distance longer than 1000m is measured.
>> var control = new OpenLayers.Control.Measure(OpenLayers.Handler.Path, {
>> This property (displaySystemUnits) is not marked as part of the API - so
>> you may have to change your app if it changes (don't imagine it will in
>> 2.x).
>> Tim
>>> Thanks,
>>> Z
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Tim Schaub
