[OpenLayers-Users] Projection problem?
Fabian Patzke
listensammler at patzi.de
Tue Jan 20 03:53:45 EST 2009
Hi there,
at the moment I am working on a university project. I am building a map
and need to get the coordinates from my map to use them in a PHP script.
There is no problem with getting them but they are in some way wrong.
What I want is to get the coordinates in EPSG:32632 just like they are
displayed in the lower left corner of the map.
For example:
I need: lat=5712116.63994 lon=565610.79249
but I get: lat=6720302.918434498 lon=1107203.4921313925
(they are not for exactly the same position)
Has anyone an idea where my problem is?
Thanks a lot in advance,
greetings Fabian
PS: my map html file:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>Rauminformationssystem Georg-August-Universität Göttingen</title>
<link rel="stylesheet" href="style.css" type="text/css" />
<!-- bring in the OpenLayers javascript library -->
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
<!-- bring in the OpenStreetMap OpenLayers layers -->
<script
src="http://www.openstreetmap.org/openlayers/OpenStreetMap.js"></script>
<!-- bring in the proj4js library -->
<script type="text/javascript"
src="proj4js/lib/proj4js-combined.js"></script>
src="proj4js/lib/defs/EPSG32632.js"></script>
src="proj4js/lib/defs/EPSG900913.js"></script>
<!-- bring in the Prototype javascript library -->
<script src="prototype.js" type="text/javascript"></script>
<script type="text/javascript">
var map;
OpenLayers.Lang.setCode('de');
// Initialise the 'map' object
function initmap() {
map = new OpenLayers.Map ("map", {
controls:[
new OpenLayers.Control.Navigation(),
new OpenLayers.Control.PanZoomBar(),
new OpenLayers.Control.Permalink(),
new OpenLayers.Control.LayerSwitcher(),
new OpenLayers.Control.MousePosition(),
new OpenLayers.Control.Attribution(),
new OpenLayers.Control.ScaleLine()
maxExtent: new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
maxResolution: 156543.0399,
numZoomLevels: 18,
units: 'm',
projection: new OpenLayers.Projection("EPSG:900913"),
displayProjection: new OpenLayers.Projection("EPSG:32632")
// Binding OSM Layers
var layer_mapnik = new OpenLayers.Layer.OSM.Mapnik("Mapnik", new
OpenLayers.Projection("EPSG:900913"));
map.addLayer(layer_mapnik);
/*var layer_tah = new OpenLayers.Layer.OSM.Osmarender("Osmarender");
map.addLayer(layer_tah);*/
// Binding WMS Layers
var wms = new OpenLayers.Layer.WMS("Gebäude",
"http://localhost:8080/geoserver/wms?service=wms&transparent=true",
{layers: 'topp:gebaeude', format: 'image/png'}, {isBaseLayer:
false, visibility: true});
var wms_raum = new OpenLayers.Layer.WMS("Räume",
{layers: 'topp:g2410_e1pos', format: 'image/png'},
{isBaseLayer: false, visibility: true});
map.addLayers([wms, wms_raum]);
// Get Info by click
map.events.register('click', map, function (e) {
document.getElementById('nodeList').innerHTML = "Lade...";
var lonlat = map.getLonLatFromPixel(e.xy).transform(
new OpenLayers.Projection("EPSG:900913"), new
//alert("You clicked near " + lonlat.lat + " N, " + lonlat.lon + " E");
x = lonlat.lon;
y = lonlat.lat;
params = "x=" + x + "&y=" +y;
var isin = new Ajax.Request (
"../postgis/coord_isin_web.php",
method: 'get',
parameters: params,
onComplete: setHTML
function setHTML( response ) {
document.getElementById('nodeList').innerHTML = response.responseText;
</script>
<meta http-equiv="content-type" content="text/html; charset=UTF-8"/>
</head>
<!-- body.onload is called once the page is loaded (call the 'initmap'
function) -->
<body onload="initmap();">
<h1 id="title">Rauminformationssystem Uni Göttingen</h1>
<!-- Permalink not in map for better usabillity -->
<!-- <a id="permalink" href="">Permalink</a><br /> -->
<div class="info">
<h2>Infos</h2>
<p style="font-size:.8em;">Für Info in die Karte klicken</p>
<div id="nodeList"></div>
</div>
<div id="map" class="map"></div>
</body>
</html>
