[OpenLayers-Users] Projection problem
David Martinez Morata damarmo at gmail.com
Wed Jan 21 08:45:43 EST 2009
Thanks for your answere!
But after a great War with all the logs files, html files, map files I
WIN!!!
Just a estrange space characters in javascript code.
Thanks for every body
Martinez Morata David
*Thinking GIS*
2009/1/21 Christopher Schmidt <crschmidt at metacarta.com>
> I think you're really not providing enough information to be helpful
> here.
> 1. Find a URL that isn't working. (Right click on an image, 'Copy URL').
> 2. Find the SRS in that URL.
> 3. Find the WEB section of your mapfile as it is when you find that
> URL.
> My guess is that -- assuming the error message is the same as before --
> the problem is that the SRS in that URL and the wms_srs string do not
> match. That is the *only* reason you get taht error message from
> MapServer.
> If they really do match, share the URL, and the full mapfile, with the
> list.
> If the error message or behavior has *changed*, you need to share what
> it has changed to.
> Regards,
> Christopher Schmidt
> MetaCarta
Thinking GIS
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090121/c1d16a34/attachment.html
