[OpenLayers-Users] how to deactivate editingtoolbar after
featureadded
G. Allegri
giohappy at gmail.com
Wed Jan 28 12:11:17 EST 2009
Thansk Alexandre for the reply. This is not exatcly what I need to achieve.
A first step is:
OpenLayers.Event.stopObservingElement(panel.controls[i+1].panel_div);
but the true behaviour I want is something like this:
panel.onClick = function fn(c,e){alert('only one feature admitted');}
but this way to overload the panel's onClick method doesn't work....
2009/1/28 Alexandre Dube <adube at mapgears.com>:
> Hi,
> Take a look at this example (1). Zoom in and out the map. You will see that
> the buttons completely disappear. That could be an other option to your
> issue.
> (1) http://dev4.mapgears.com/bdga/bdgaWFS-T.html
> Regards,
> Alexandre
> G. Allegri wrote:
>> Sorry, I've sent too fast the solution. It works, but how can I
>> overload the onClick event on the control to alert the user with "a
>> feature has been already added"?
>> In this case I don't have to stop observing the click but I need to
>> handle it in a custom way...
>> 2009/1/28 G. Allegri <giohappy at gmail.com>:
>>> Solved (somehow...):
>>> function locAdded(feature){
>>> for(i=0;i<3;i++){
>>> panel.controls[i+1].deactivate();
>>> giovanni
>>>> Hello list,
>>>> I'm using the editingtoolbar control panel. I need to disable it after
>>>> any feature has been added (point, line or polygon), and reactivate it
>>>> if the feature gets deleted.
>>>> I've seen that calling:
>>>> panel.controls[1].deactivate();
>>>> panel.controls[2].deactivate();
>>>> panel.controls[3].deactivate();
>>>> deactivate the controls unitl the user click on the panel again...
>>>> this is not what I need. In fact the panel control has an onClick
>>>> handler that activate the control on which the onClick event has
>>>> happened (line 212 in Panel.js).
>>>> I've tried deactivating directly the panel, but the panel gets deleted.
>>>> I need the panel to remain visible but "unclickable", until the unique
>>>> feature has been deleted from the layer.
>>>> I've tried to overload the onClick panel's method, but I couldn't get
>>>> it to work...
>>>> Thanks for any hint.
>>>> giovanni
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
