[OpenLayers-Users] Doubt with layers
Ivan Grcic
igrcic at gmail.com
Wed Jan 28 15:01:41 EST 2009
Hi, check options:
layer.isBaseLayer(true/false)
map.setBaseLayer(layer)
Cheers
On Wed, Jan 28, 2009 at 8:51 PM, Rafael chacón <rafaelchacon at gmail.com> wrote:
> Hi, I have the following layers defined:
> roads = new OpenLayers.Layer.MapServer( "Roads",
> "http://192.168.1.103/cgi-bin/mapserv?map=us_states.map",
> {layers: 'us_roads', transparent:'true'});
> gps = new OpenLayers.Layer.MapServer( "GPS",
> {layers: 'gps_points', transparent: 'true'});
> roads.setVisibility(false)
> gps.setVisisibility(false)
> Both layers work, but I have the following behavior: when one of the layers
> is active the other one disappears. Suppose I chose first the roads, then
> it show the roads. Then I select gps, then it shows the gps points but roads
> start to disappear. Any ideas why this happens??
> Thanks in advance.
> Rafael Chacon,
> "El hombre es la medida de todas las cosas". Protagoras
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
