[OpenLayers-Users] How to - severable clickable WFS layers ?
Asle Benoni asle.benoni at gmail.com
Wed Jun 10 10:34:10 EDT 2009
And to specify the array elements would be? Any help?
/asle
2009/6/10 Christopher Schmidt <crschmidt at metacarta.com>
> On Wed, Jun 10, 2009 at 01:11:27PM +0200, Asle Benoni wrote:
> > Hello,
> > I try to specify the layer array like this "map.layers[2,3,4,5]" but that
> > does not work. Is this correct?
> This is not corect Javascript syntax in any way that I'm aware of.
> -- Chris
> > I always get popups only on the last layer I
> > have specified. Is my way of specifying the layers array correct? How do
> I
> > check what version of OpenLayers I have?
> > A lot of questions! Thanks.
> > /asle
> > 2009/6/8 Asle Benoni <asle.benoni at gmail.com>
> > > Thanks! Sure enough I was mixing in other layers.
> > > I chose only the WFS layers now but I am only able to click on the last
> > > layer that is listed. If I put "map.layers[2,3,4]", I get popups for
> layer 4
> > > but no one else.
> > > selectControl = new
> > > OpenLayers.Control.SelectFeature(map.layers[2,3,4,5],{onSelect:
> > > onFeatureSelect, onUnselect: onFeatureUnselect});
> > >            map.addControl(selectControl);
> > >            selectControl.activate();
> > >            function onPopupClose(evt) {
> > >                 selectControl.unselect(selectedFeature);
> > > I wonder if this is a good approach for what I want to accomplish? I
> looked
> > > at this example which uses OpenLayers switch features.
> http://gis.ibbeck.de/ginfo/apps/OLExamples/OL26/examples/styles_unique_with_group.html
> > > I would else have to hide a layer when another is shown since users
> would
> > > not understand why every marker in all visible layers are not
> clickable.
> > > Thanks for any input!!
> > > /asle
> > > 2009/6/8 Christopher Schmidt <crschmidt at metacarta.com>
> > > On Mon, Jun 08, 2009 at 03:59:03PM +0200, Asle Benoni wrote:
> > >> > Hi,
> > >> > I just wonder how I know if I have OpenLayers 2.8? I have downloaded
> > >> from
> > >> > trunk but the date for OpenLayers.js is 31.03.2009. Or do I have to
> grab
> > >> > some special files. *map.layers* is my arrayname?
> > >> > I tried your suggestion but when I write:
> > >> > selectControl = new
> > >> OpenLayers.Control.SelectFeature(*map.layers*,{onSelect:
> > >> > I get this error in Firebug and the page is blank:
> > >> > *layer.renderer is undefined
> > >> > Does this mean I am still using too old OpenLayers.js?
> > >> No. It means you have passed in one or more layers in your array that
> > >> are *not* vector layers.
> > >> -- Chris
> > >> > /asle
> > >> > 2009/6/8 Eric Lemoine <eric.lemoine at camptocamp.com>
> > >> > > On Sunday, June 7, 2009, Asle Benoni <asle.benoni at gmail.com>
> wrote:
> > >> > > > Hello,
> > >> > > > I have a map using a MapFish framework but I think this must be
> a
> > >> > > OpenLayers question.
> > >> > > > I have several WFS layers from GeoServer where I use the
> attributes
> > >> to
> > >> > > fill the popup.  Only problem is that I can only click on markers
> in
> > >> one
> > >> > > layer at a time. The user sees all the layers, some buildings,
> another
> > >> layer
> > >> > > with churches etc. but can only click on on layer. How do I solve
> > >> this? I
> > >> > > have now one layer for each type of buildings and I want to be
> able to
> > >> turn
> > >> > > on and off different buildings so that is why they are in separate
> > >> layers.
> > >> > > Is it possible to still use many layers and bee able to click on
> > >> popups from
> > >> > > different layers. Or is my approach unnecessary difficult? Glad
> for
> > >> any
> > >> > > help!
> > >> > > > I use this for the WFS layer:
> > >> > > >                 createWfsLayer(
> > >> > > >                     "Teknisk industri",
> http://naturkart.no:8080/geoserver/wfs?SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&SRS=EPSG%3A32633&BBOX=40484.8125,6401353.125,760135.8125,6687724.125
> > >> > > >                         typename:
> > >> "kulturminner_ns:tekniskindustrielt",
> > >> > > >                         srsName: "EPSG:32633",
> > >> > > >                         maxfeatures: 200},{
> > >> > > >                         extractAttributes:true,
> > >> > > >                         visibility:false
> > >> > > > ...same code for each layer....
> > >> > > > // Popup code, define for each layer with markers:
> > >> > > >          selectControl = new
> > >> > > OpenLayers.Control.SelectFeature(map.layers[0],{onSelect:
> > >> onFeatureSelect,
> > >> > > >                 selectControl1.unselect(selectedFeature);
> > >> > > >          selectControl1 = new
> > >> > > OpenLayers.Control.SelectFeature(map.layers[1],{onSelect:
> > >> onFeatureSelect,
> > >> > > >            map.addControl(selectControl1);
> > >> > > >            selectControl1.activate();
> > >> > > > // etc...... for every layer with marker
> > >> > > Instead of creating one select control for each layer create only
> one
> > >> > > and give it all the layers:
> > >> > > sc = new OpenLayers.Control.SelectFeature(array_of_layers, {...});
> > >> > > you'll need OL 2.8 for this (or trunk)
> > >> > > Cheers,
> > >> > > > // Now the popup functions used:
> > >> > > >         function onFeatureSelect(feature) {
> > >> > > >             selectedFeature = feature;
> > >> > > >             popup = new OpenLayers.Popup.FramedCloud("chicken",
> > >> > > feature.geometry.getBounds().getCenterLonLat(),
> > >> > > >                                      new
> OpenLayers.Size(100,200),
> > >> > > >                     "<h2>" +feature.attributes.gardsnavn +
> > >> > > >                     "</h2>Type: "+ feature.attributes.art +
> > >> > > >                      "<br />Kommune: "+ feature.attributes.komm
> > >> > > >                      "<br />Beskrivelse<br /><a href='" +
> > >> > > feature.attributes.urltilpdfark +
> > >> > > >                      "' target=blank><img src='
> > >> > > http://naturkart.no:8080/geoserver/images/logo.png' border='0'
> > >> > > alt='naturkart'></a>", null, true, onPopupClose);
> > >> > > >             feature.popup = popup;
> > >> > > >             map.addPopup(popup);
> > >> > > >         function onFeatureUnselect(feature) {
> > >> > > >             map.removePopup(feature.popup);
> > >> > > >             feature.popup.destroy();
> > >> > > >             feature.popup = null;
> > >> > > Eric Lemoine
> > >> > > Camptocamp France SAS
> > >> > > Savoie Technolac, BP 352
> > >> > > 73377 Le Bourget du Lac, Cedex
> > >> > > Tel : 00 33 4 79 44 44 96
> > >> > > Mail : eric.lemoine at camptocamp.com
> > >> > > http://www.camptocamp.com
> > >> > _______________________________________________
> > >> > Users mailing list
> > >> > Users at openlayers.org
> > >> > http://openlayers.org/mailman/listinfo/users
> > >> Christopher Schmidt
> > >> MetaCarta
> > Users mailing list
> Christopher Schmidt
> MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090610/1ebb9f35/attachment.html
