[OpenLayers-Users] Error displaying map in IE8 - VML.js
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Jun 12 02:53:27 EDT 2009
Note sure what the actual problem is, but there are notes that the patch
does not solve all issues.
There is a nother fix mentioned, namely the one in comment #20:
http://trac.openlayers.org/ticket/1910#comment:20
This effectively places IE8 in IE7 compatibility mode, and it works.
Although it's not the correct long term solution, you can use it until
the issue is fixed more permanently.
Regards, Kenneth Skovhede, GEOGRAF A/S
Asle Benoni skrev:
> Hello,
> I have a MapFish setup with everything working fine in all browsers
> exept IE8. When I load the page in IE8 the map is blank and a message
> says.
> *Webpage error details
> User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1;
> Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR
> 3.0.30729; Media Center PC 6.0)
> Timestamp: Thu, 11 Jun 2009 10:21:53 UTC
> Message: Unspecified error.
> Line: 98
> Char: 9
> Code: 0
> URI:
> http://naturkart.no/kulturminnekart/mfbase/openlayers/lib/OpenLayers/Renderer/VML.js
> So I found this patch for VML.js:
> http://trac.openlayers.org/attachment/ticket/1910/IE8_Generic_CSSPrefix_Selectors.patch
> After applying the patch I now get this message in IE8. This must be a
> OpenLayers problem then. Anyone seen this before and fixed it?
> "* Your browser does not support vector rendering. Currently supported
> renderers are:
> SVG
> VML
> CANVAS*"
> /asle
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090612/a9fcd40d/attachment.html
