[OpenLayers-Users] Framed Cloud Popup - Tail interferring with layer
soatley
shawn at niagarafalls.ca
Fri Jun 12 07:06:40 EDT 2009
I am having a problem using the popups to display data and have confirmed it
with the 'Popup Matrix' example :
http://www.openlayers.com/dev/examples/popupMatrix.html
To re-create, click on the very bottom row of popups (overflow:hidden) of
the first 'min size (400X400)' column. You should see the popup appear
above the row. Now try and click on one of the markers right by the tail.
The easiest one to try is the marker right above the one you just clicked
on.
This happens in Firefox, Safari and IE 8 (haven't tried 7). In
Firefox/Safari, it is worse than IE. In IE, it is just the markers by the
tail that are affected. In the others, it is the markers that are below the
popup but parallel to the tail.
This is a problem for me because I use popups to show property information
and quite often, the properties are beside one-and-other or in that area
below the popup.
Has anyone tried a work-around for this?
Thanks,
Shawn
View this message in context: http://n2.nabble.com/Framed-Cloud-Popup---Tail-interferring-with-layer-tp3067060p3067060.html
