[OpenLayers-Users] Error displaying map in IE8 - VML.js
Asle Benoni
asle.benoni at gmail.com
Fri Jun 12 09:52:54 EDT 2009
Thanks Kenneth, the compatibility hack works fine. I would rather not hack
VML.js but I see this hack is newer than the one I tried. As long as the
quickfix works I am satisfied. But would like to know if some have success
with it and if it is included in future OL release.
/asle
2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
> Hi,
> On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
> A/S<ks at geograf.dk> wrote:
> > Note sure what the actual problem is, but there are notes that the patch
> > does not solve all issues.
> > There is a nother fix mentioned, namely the one in comment #20:
> > http://trac.openlayers.org/ticket/1910#comment:20
> > This effectively places IE8 in IE7 compatibility mode, and it works.
> > Although it's not the correct long term solution, you can use it until
> > the issue is fixed more permanently.
> The latest patch [1] should fix all vector layer issues in IE8. It
> would be nice to get some feedback if this is really the case.
> Regards,
> Andreas.
> [1]
> http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090612/72324b0c/attachment.html
