[OpenLayers-Users] Error displaying map in IE8 - VML.js
Nathan Gerber
ngerber999 at gmail.com
Fri Jun 12 14:40:44 EDT 2009
All,
Using this patch:
http://trac.openlayers.org/attachment/ticket/1910/openlayers-1910.patch
I have run tests using various versions of Internet Explorer
IE6 (XP): patch works fine, vectors render with labels
IE7 (XP): patch works fine, vectors render but not with labels while in
standards compliance mode
IE8 (Vista): patch works fine, vectors render with labels
Nathan Gerber
On Fri, Jun 12, 2009 at 10:01 AM, Christopher Schmidt <
crschmidt at metacarta.com> wrote:
> On Fri, Jun 12, 2009 at 03:52:54PM +0200, Asle Benoni wrote:
> > Thanks Kenneth, the compatibility hack works fine. I would rather not
> hack
> > VML.js but I see this hack is newer than the one I tried. As long as the
> > quickfix works I am satisfied. But would like to know if some have
> success
> > with it and if it is included in future OL release.
> It can't be included in a future OL release until people test it. If
> you're unwilling to test it, the chances it will be included decrease.
> Please help test it if you care about it.
> -- Chris
> > /asle
> > 2009/6/12 Andreas Hocevar <ahocevar at opengeo.org>
> > > Hi,
> > > On Fri, Jun 12, 2009 at 8:53 AM, Kenneth Skovhede, GEOGRAF
> > > A/S<ks at geograf.dk> wrote:
> > > > Note sure what the actual problem is, but there are notes that the
> patch
> > > > does not solve all issues.
> > > > There is a nother fix mentioned, namely the one in comment #20:
> > > > http://trac.openlayers.org/ticket/1910#comment:20
> > > > This effectively places IE8 in IE7 compatibility mode, and it works.
> > > > Although it's not the correct long term solution, you can use it
> until
> > > > the issue is fixed more permanently.
> > > The latest patch [1] should fix all vector layer issues in IE8. It
> > > would be nice to get some feedback if this is really the case.
> > > Regards,
> > > Andreas.
> > > [1]
> > > Andreas Hocevar
> > > OpenGeo - http://opengeo.org/
> > > Expert service straight from the developers.
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090612/cd7e548d/attachment.html
