[OpenLayers-Users] Ticket #2080, Optical zoom bug
Andreas Hocevar
ahocevar at opengeo.org
Tue Jun 16 08:19:11 EDT 2009
Hi Mårten,
the problem is that page zooming in IE7 is somewhat broken. If you
google for IE7 and page-zoom, you will find several sources reporting
a similar issue, none with a solution unfortunately (e.g. [1]).
The good news is: in IE8 it works fine.
Regards,
Andreas.
[1] http://www.yui-ext.com/forum/showthread.php?t=38454
On Tue, Jun 16, 2009 at 1:03 PM, Swärd Mårten<marten.sward at smhi.se> wrote:
> Hello folks!
> I have a problem with an application when using IE7, the problem is exaktly
> as described in ticket 2080, http://trac.openlayers.org/ticket/2080
> Does anyone know what causes this and could point me to a direction where to
> start searching for a solution?
> Any information that can narrow down the search would be appreciated…
> Best regards, Mårten
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
