[OpenLayers-Users] Ticket #2080, Optical zoom bug
Andreas Hocevar
ahocevar at opengeo.org
Wed Jun 17 03:28:53 EDT 2009
On Wed, Jun 17, 2009 at 7:36 AM, Swärd Mårten<marten.sward at smhi.se> wrote:
> Thanks for the reply! I know that the problem is in IE7 and not a bug specific to OL, but it's quite critical for us to make a "workaround" for this. So my hope was that it would be possible to somehow fix this "Bill Gates bug" by adjusting some code I OL.. The problem is that I (we) don't know which part of the OL code that this IE7-bug affects so it's a bit difficult to try out some workarounds..
> Do you, or anyone, know wich classes this IE7 bug affects?
The place to fix it would be in Events.js by adding some pixel
coordinate modifications in the getMousePosition method. But don't ask
me which modification is needed, the incorrect positions seem to be
pretty unpredictable.
Regards,
Andreas.
> Best regards, Mårten
> -----Ursprungligt meddelande-----
> Från: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] För Andreas Hocevar
> Skickat: den 16 juni 2009 14:19
> Till: Swärd Mårten
> Kopia: users at openlayers.org
> Ämne: Re: [OpenLayers-Users] Ticket #2080, Optical zoom bug
> Hi Mårten,
> the problem is that page zooming in IE7 is somewhat broken. If you
> google for IE7 and page-zoom, you will find several sources reporting
> a similar issue, none with a solution unfortunately (e.g. [1]).
> The good news is: in IE8 it works fine.
> Regards,
> Andreas.
> [1] http://www.yui-ext.com/forum/showthread.php?t=38454
> On Tue, Jun 16, 2009 at 1:03 PM, Swärd Mårten<marten.sward at smhi.se> wrote:
>> Hello folks!
>> I have a problem with an application when using IE7, the problem is exaktly
>> as described in ticket 2080, http://trac.openlayers.org/ticket/2080
>> Does anyone know what causes this and could point me to a direction where to
>> start searching for a solution?
>> Any information that can narrow down the search would be appreciated...
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Users mailing list
Andreas Hocevar
