[OpenLayers-Users] Scalebar not visible
sendeman
martijnsendenspam at gmail.com
Fri Jun 19 05:07:59 EDT 2009
Hi again,
I'm still struggling with the scalebar problem I described earlier (see
below). Does anyone see an error in the code I posted? Do I need to provide
additional information? Please let me know if I need to give more input.
Thanks again in advance!
Best regards,
Martijn Senden.
sendeman wrote:
> Hi All,
> Does anyone have a solution for the problem I described earlier (see
> below)? I haven't been able to tackle it yet. Thanks a lot in advance!
> Best regards,
> Martijn Senden.
> sendeman wrote:
>> Hi all!
>> I'm trying to add a scalebar to my mapserver + openlayers webapp. I tried
>> implementing
>> http://dev.openlayers.org/addins/scalebar/trunk/examples/scalebar.html
>> the online example into my own page, but until now, I haven't succeeded.
>> I used firebug to see the generated source and the javascript does add
>> divs for the scalebar, I just don't see it anywhere. I have made no
>> changes to the css or javascript, just changed the location and filename.
>> The src values of the scripts and href of the linked stylesheet are
>> correct.
>> I added the code I used below.
>> Does anyone see what's going wrong? Because I don't. :-)
>> Thanks in advance, any help will be greatly appreciated!
>> Best regards,
>> Martijn Senden.
>> _________________________________________________________________
>> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
>> "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
>> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"><head>
>> <title>Untitled</title>
>> <style type="text/css">
>> body,
>> html {
>> overflow: hidden;
>> height: 100%;
>> #map {
>> position: absolute;
>> z-index:1;
>> top: 100px;
>> bottom: 50px;
>> left: 0;
>> width: 70%;
>> /* height:80%; */
>> border: 1px solid black;
>> background: red;
>> #scalebar {
>> position: absolute;
>> right: 0;
>> bottom: 50px;
>> width: 25%;
>> height: 200px;
>> border: 1px solid #000;
>> </style>
>> <!--[if lte IE 8]>
>> #map {
>> bottom: auto;
>> height: expression(document.documentElement.clientHeight - 150 +"px");
>> </style>
>> <![endif]-->
>> <script type="text/javascript"
>> src="http://openlayers.org/api/OpenLayers.js"></script>
>> src="javascript/openlayers_scalebar.js"></script>
>> <link href="css/scalebar.css" rel="stylesheet" type="text/css"
>> media="screen">
>> <script type="text/javascript">
>> function init(){
>> //Create a new OpenLayers mapwindow with associated controls
>> var map = new OpenLayers.Map('map', {
>> projection: "EPSG:28992",
>> maxResolution: 1328.125,
>> numZoomLevels: 14,
>> maxExtent : new OpenLayers.Bounds(-23500,289000,316500,629000),
>> restrictedExtent: new OpenLayers.Bounds(80000,442000,88000,452000),
>> units : "meters",
>> controls: [
>> new OpenLayers.Control.ZoomToMaxExtent(),
>> new OpenLayers.Control.PanZoomBar({zoomWorldIcon: true}),
>> new OpenLayers.Control.LayerSwitcher({'ascending':false}),
>> new OpenLayers.Control.MouseDefaults(),
>> new OpenLayers.Control.KeyboardDefaults()
>> // Add Spoortunnel Delft Mapserver .map-files
>> layer = new OpenLayers.Layer.MapServer( "Topografie",
>> "/geoviewerbin/mapserv.exe", {map:
>> "c:/OSGeo4W/apps/geoviewer/maps/spoortunnel.map", layers: "Topografie"}
>> map.addLayer(layer);
>> //Add a scalebar to the map
>> scalebar = new OpenLayers.Control.ScaleBar();
>> map.addControl(scalebar);
>> map.zoomToExtent(new OpenLayers.Bounds(83600,446000,84600,448200));
>> window.onload=init;
>> </script>
>> </head><body>
>> <div id="map"></div>
>> </body></html>
View this message in context: http://n2.nabble.com/Scalebar-not-visible-tp3086564p3118597.html
