[OpenLayers-Users] How to calculate Bounds for Image Layer
Example?
Jan Martin
janmartin3 at googlemail.com
Wed Jun 24 05:12:04 EDT 2009
Me again,
I gave your hint a try, but it didn't work. Seems to be projection related.
As soon as there is an OSM Layer it seems one needs to project the Church
picture.
Anyway, I gave up on that idea, and started moving the map to another div,
and then display the Church picture instead, like this:
OpenLayers.Util.getElement('map2').innerHTML =
OpenLayers.Util.getElement('map').innerHTML ;
OpenLayers.Util.getElement('map').innerHTML = "<img
src=\"pictures/"+globalresponse.responseText+"\"\/\>";
Problem is, the map doesn't work anymore afterwards?
Actually I am looking for this layout:
One big picture of e.g. a Church, and a small map below (or in a corner of
the picture).
Late render could probably re-render the map, but all browsing done to that
moment would be lost.
Or can one really just display the overview map, without the map itself?
Ideas please?
Thanks,
Jan
On Wed, Jun 24, 2009 at 10:48 AM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hi,
> the image layer was not made for displaying non-geographic images, but
> for maps. It seems you want to use OpenLayers to display images in the
> map pane, and for this we may have a better solution for you.
> Have a look at
> http://www.openlayers.org/dev/examples/georss-flickr.html
> This example shows you how to display images on point locations, and in
> popups (click on an image to see it).
> As for calculating the image size and the aspect ratio: that's exactly
> what we do for externalGraphic point symbols
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Renderer/VML.js#L365
> So if you want to do this, the solution is to register an
> onreadystatechange listener before setting img.src.
> Regards,
> Andreas.
> Ilya Braude wrote:
> > Andreas Hocevar wrote:
> >>> Problem is how to calculate OpenLayers.Bounds?
> >>> Simply replacing
> >>> new OpenLayers.Bounds(-180, -88.759, 180, 88.759),
> >>> by
> >>> new OpenLayers.Bounds(-20037508, -20037508, 20037508, 20037508.34)
> >>> did not work.
> >>> (It just blows up a single pixel to cover the whole map-div.)
> >> The easiest for image layers that do not have to align with a map is
> >> to set the bounds according to the image size. So let's assume you
> >> have an image, like the one in the example, with is 580 pixels wide
> >> and 288 pixels high, then the best approach is to set the bounds to 0,
> >> 0, 580, 288.
> > I have a similar use case where I do this in order to keep the proper
> > aspect ratio for the image. However, is there a way to have the bounds
> > be calculated automatically without me having to know the image size a
> > priori? For example, if the image URL is dynamic or user-submitted.
> > The only way I can think to do this (and I haven't tested this) is to
> > have the browser pre-load the image in a new <img/> tag, read the size
> > attributes from it, and then use those values for creating the image
> > layer. In this case, how do I know that the image has been downloaded
> > for me to read those attributes?
> > Something like:
> > var img = new Image();
> > img.src = "http://path.to/img/url";
> > var bounds = new OpenLayers.Bounds(0, 0, img.width, img.height);
> > Is there a way that OpenLayers can handle this if I don't care about
> > the extent of the image layer, just that it keeps it's aspect ratio
> > without me having to specify the correct (in terms of aspect ratio)
> > bounds?
> >>> So how to calculate OpenLayers.Bounds to display the image at its
> >>> original
> >>> 100% size?
> >> See above.
> > I assume that by "above" you mean using the pixel size of the image
> > for the bounds? Would it make sense that this would be the default
> > behavior for an image layer and implemented by OL directly?
> > Thanks,
> > Ilya
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090624/9da27953/attachment.html
