[OpenLayers-Users] Printing in IE6
Andreas Hocevar
ahocevar at opengeo.org
Mon Jun 29 09:31:07 EDT 2009
IE6 cannot handle transparency of 24bit PNGs without an alpha hack,
and this alpha hack only works for the browser view.
If your layers all come from the same server, you can create one map
image that contains all your map layers. This is just one of the
solutions that are described in detail at [1].
Regards,
Andreas.
[1] http://trac.openlayers.org/wiki/Printing
On Mon, Jun 29, 2009 at 3:22 PM, <jim.meyer at concept-solutions.com> wrote:
> Hello,
> I have been trying to figure out why when I print in IE6 using the native
> browser javascript print() method that only the top layer of my map
> displays. My map is comprised of tiled PNGs. The screen renders the map
> properly. It is only the printed version of the map that isn’t working.
> Any suggestions would be greatly appreciated.
> Just an FYI… at this point upgraded to later versions of IE isn’t a
> possibility.
> Thanks,
> Jim
> James B. Meyer
> Java Programmer
> Concept Solutions, Inc.
> (703) 472-7838
> 11600 Sunrise Valley Drive
> Suite 300
> Reston, VA 20191
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
