[OpenLayers-Users] Temporary point from lonlat
    Lehtonen, Mika
    mika at digikartta.net
    Wed Mar  4 02:07:43 EST 2009
Hi Hugo,
I have this function in one of my applications. markers is a marker
layer. Just started to wonder where that clearMarkers( ) is coming from.
It's not part of the API, is it? Anyway, this function works  for me.
Maybe you can get some ideas out of it anyway.
- mika -
function showAddress(address)    {
                    var size = new OpenLayers.Size(20,34);
                    var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
                    var icon = new
OpenLayers.Icon('http://boston.openguides.org/markers/RED.png',size,offset);
                    var geocoder = new GClientGeocoder();
                    if (geocoder) {
                        geocoder.getLatLng(
                        address,
                        function(point) {
                            if (!point) {
                                alert(address + " couldn't be found!");
                            } else {
                                var lonLat = new
OpenLayers.LonLat(point.x,point.y).transform(new
OpenLayers.Projection("EPSG:4326"),
                                new OpenLayers.Projection("EPSG:900913"));
                                map.setCenter(lonLat,7);
                    markers.clearMarkers();
                    markers.addMarker(new OpenLayers.Marker(lonLat, icon));
Hugo kirjoitti:
> Hello list,
> I have google geocoder inside my application and i would like to add a
> temporary/on the fly point or png on the geocoded address. This is,
> after entering an address, i have a setCenter to that adress but would
> like to put just something calling the attention to those coordinates.
> If i add new address, then this point would disapear and another point
> would appear in the correct location.
> What do you advise me to use in this situation???
> Thanks for your help.
> Regards,
> Hugo
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
