[OpenLayers-Users] ArcGIS Server 9.3 example code?
Linde Ackermans
roselinda.ackermans at ec.europa.eu
Fri Mar 6 02:55:36 EST 2009
Hello,
Not sure what you want exactly, but I suppose you want an example on how to
call for a WMS service served by ArcGis Server 9.3 ?
This is how :
var map = new OpenLayers.Map($('olmap'));
var boundaries = new OpenLayers.Layer.WMS("Layer1",
"http://yourservername:8399/arcgis/services/yourWMSservicename1/mapserver/wmsserver",
{ layers: "0", format: "image/png"} );
var urbanaudit = new OpenLayers.Layer.WMS("Layer2",
"http://yourservername:8399/arcgis/services/yourWMSservicename2/mapserver/wmsserver",
{ layers: "0,1", transparent: "true", format: "image/png"} );
map.addLayers([Layer1, Layer2]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToMaxExtent();
ArcGIS Server uses numbers for it's layers names ! Don't confuse with the
layers' description.
To see which number corresponds to which layer, check the capabilities file.
That's the only place were you can get this info.
View this message in context: http://n2.nabble.com/ArcGIS-Server-9.3-example-code--tp2427664p2434423.html
