[OpenLayers-Users] OL Map setcenter problem with IE
Emmanuele Sordini emmanuele.sordini at gmail.com
Tue Mar 10 10:04:11 EDT 2009
On Fri, Mar 6, 2009 at 2:09 PM, Christopher Schmidt
<crschmidt at metacarta.com> wrote:
> Sounds like you may be initializing the map before IE has completely
> drawn the div, and Google therefore gets a size of 0 initialized at some
> point.
That was exactly my reasoning on the problem.
> At the end of your function, try a map.updateSize() to kick the
> map; it may help.
It did help, but putting it at the end of the init() function (i.e.
exactly where the setCenter() call I mentioned in my first post was
located) wasn't enough. Instead, using a 1-second delayed
timeout/callback with a map.updateSize() did the trick. Here's the
code snippet, just in case it may come in handy for someone else:
    var timeoutId = null;
    function redrawCallback() {
        if (map != null) {
        	map.updateSize();
        if (timeoutId != null) {
            window.clearTimeout(timeoutId);
and at the end of the init() function:
timeoutId = window.setTimeout(redrawCallback, 1000);
The only drawback with this approach is that you see the map "flicker"
for a while. But it's the only way I found around the problem. I just
wonder why FF and IE are showing such a different behavior...
Thanks
Emmanuele
