[OpenLayers-Users] tomcat and proxy
Paulo Cesar Rocha paulorangelrocha at gmail.com
Tue Mar 10 21:55:21 EDT 2009
I changed tomcat web.xml  and copied the proxy.cgi python script from the OL
example directory to the /webapps//cgi-bin/ directory (I'm using Vista,
Tomcat5.5 and Geoserver). When I type the url
http://localhost:8080/cgi-bin/proxy.cgi in IE it lists openlayers proxy
instead of openlayers hompage:
  #!c:\python25\python.exe -u """This is a blind proxy that we use to get
around browser restrictions that prevent the Javascript from loading pages
not on the same server as the Javascript. This has several problems: it's
less efficient, it might break some sites, and it's a security risk because
people can use this proxy to browse the web and possibly do bad stuff with
it. It only loads pages via http and https, but it can load any content
type. It supports GET and POST requests.""" import urllib2 import cgi import
sys, os # Designed to prevent Open Proxy type stuff. allowedHosts = ['
www.openlayers.org', 'openlayers.org', 'labs.metacarta.com', '
world.freemap.in', 'prototype.openmnnd.org', 'geo.openplans.org', '
sigma.openplans.org', 'localhost:8080'] method =
os.environ["REQUEST_METHOD"] if method == "POST": qs =
os.environ["QUERY_STRING"] d = cgi.parse_qs(qs) if d.has_key("url"): url =
d["url"][0] else: url = "http://www.openlayers.org" else: fs =
cgi.FieldStorage() url = fs.getvalue('url', "http://www.openlayers.org")
try: host = url.split("/")[2] if allowedHosts and not host in allowedHosts:
print "Status: 502 Bad Gateway" print "Content-Type: text/plain" print print
"This proxy does not allow you to access that location (%s)." % (host,)
print print os.environ elif url.startswith("http://") or
url.startswith("https://"): if method == "POST": length =
int(os.environ["CONTENT_LENGTH"]) headers = {"Content-Type":
os.environ["CONTENT_TYPE"]} body = sys.stdin.read(length) r =
urllib2.Request(url, body, headers) y = urllib2.urlopen(r) else: y =
urllib2.urlopen(url) # print content type header i = y.info() if
i.has_key("Content-Type"): print "Content-Type: %s" % (i["Content-Type"])
else: print "Content-Type: text/plain" print print y.read() y.close() else:
print "Content-Type: text/plain" print print "Illegal request." except
Exception, E: print "Status: 500 Unexpected Error" print "Content-Type:
text/plain" print print "Some unexpected error occurred. Error text was:", E
What's wrong?
Tia.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090310/6bf8717c/attachment.html
