[OpenLayers-Users] Openlayers does not support the 31297 epsg
code?
"tschobber tschöbbi"
tschobber at gmx.at
Thu Mar 12 05:44:04 EDT 2009
Thanks again - it's working now, but I still have distortions in the map (but the epsg code is all over the same) and when I load the image the first time its extremely zoomed in and I'm not able to zoom out... additionally my firefox browser error console show's me a javascript error that there was an error handling the data for attribute 'filter'... (I translated the error message in english so It's not the original one).
I'm new to that stuff and I hope anyone can bring some light to it :) ...
Here's the edited html code I'm using:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>Mapnik WMS Test</title>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<style type="text/css">
html, body { height: 100%; }
body {margin: 0px;}
#map {
width: 100%;
height: 100%;
</style>
<script src="lib/OpenLayers.js"></script>
<script type="text/javascript">
var map;
function init(){
var bbox = new OpenLayers.Bounds(384619.116883103, 467965.222077892, 505102.701298797, 534231.193506524);
var map_options = {maxExtent: bbox, projection:"EPSG:31297",units: "meters", numZoomLevels: 27, maxResolution: 5};
map = new OpenLayers.Map('map',map_options);
var mapserver_agg = new OpenLayers.Layer.WMS("AGG Mapserver","http://gaia.geo.univie.ac.at/cgi-bin/mapserv?map=/srv/www/cgi-bin/data/oerok_agg2.map",{layers: ['land_grenzen01','layer_mapany_080305_3ba6226287c1622', 'bezirk_grenzen_01', 'land_grenzen01','staat01','fluss01', 'stadt01']},{isBaseLayer:true, reroject: true});
map.addLayers([mapserver_agg]);
map.zoomToMaxExtent();
</script>
</head>
<body onload="init()">
<h2 style="position:absolute; z-index:10000; left: 100px;">Mapnik WMS Test</h2>
<div id="map">
</div>
</body>
</html>
Martin
-------- Original-Nachricht --------
> Datum: Wed, 11 Mar 2009 09:56:37 -0400
> Von: Christopher Schmidt <crschmidt at metacarta.com>
> An: "tschobber tschöbbi" <tschobber at gmx.at>
> CC: users at openlayers.org
> Betreff: Re: [OpenLayers-Users] Openlayers does not support the 31297 epsg code?
> On Wed, Mar 11, 2009 at 02:19:52PM +0100, "tschobber tschöbbi" wrote:
> > Hey Chris,
> Reply to the list.
> > thanks for the fast answer, but I guess I'm doing so: Thats the
> beginning of my mapfile:
> OpenLayers doesn't read the mapfile. You have to duplicate this
> information in the OpenLayers Javascript config.
> -- Chris
> > MAP
> > EXTENT 384619.116883103 467965.222077892 505102.701298797
> 534231.193506524
> > FONTSET "../../data/fonts/fonts.txt"
> > IMAGECOLOR 255 255 255
> > # IMAGETYPE png24
> > SYMBOLSET "../../includes/sys.sym"
> > SHAPEPATH "data/"
> > SIZE 700 385
> > STATUS ON
> > UNITS METERS
> > NAME "Atlas"
> > OUTPUTFORMAT
> > NAME 'AGG'
> > DRIVER AGG/PNG
> > IMAGEMODE RGB
> > END
> > PROJECTION
> > "init=epsg:31297"
> > END
> > ... directly after this there is the wms specification (see last
> message).
> > > Datum: Wed, 11 Mar 2009 09:06:07 -0400
> epsg code?
> > > On Wed, Mar 11, 2009 at 01:54:55PM +0100, "tschobber tschöbbi" wrote:
> > > > Hi,
> > > > I want to project a mapfile via Openlayers, but Openlayers prints
> the
> > > following error message:
> > > > "msWMSLoadGetMapParams(): WMS server error . Invalid SRS given : SRS
> > > must be valid for all requested layers."
> > > > All my layers have the projection epsg code 31297 and I configured
> wms
> > > like this:
> > > You didn't specify a projectin anywhere in your OpenLayers code. You
> > > need to specify a maxExtent, maxResolution, and projection properties:
> http://faq.openlayers.org/map/how-do-i-set-a-different-projection-on-my-map/
> > > > WEB
> > > > IMAGEPATH "/tmp/ms_tmp/"
> > > > IMAGEURL "/ms_tmp/"
> > > > MAXSCALE 3e+06
> > > > METADATA
> > > > "wms_srs" "epsg:31297"
> > > > "wms_onlineresource"
> "http://map.gis.univie.ac.at/cgi-bin/mapserv?map=/srv/www/htdocs/isohis/includes/control_mapfile.map&"
> > > > "wfs_srs" "epsg:31297"
> > > > "wfs_title" "ISOHIS - WFS"
> > > > "wfs_onlineresource"
> > > > "wms_title" "ISOHIS -WMS"
> > > > END
> > > > MINSCALE 100000
> > > > QUERYFORMAT text/html
> > > > LEGENDFORMAT text/html
> > > > BROWSEFORMAT text/html
> > > > END
> > > > I also found a file named epsg (proj4) and this file contains this
> code
> > > so I'm a bit confused. I also tried this example with an other code
> but
> > > then the image has distortions - but it works. Here's the ol_map.htm
> I'm
> > > using:
> > > > <head>
> > > > body {margin: 0px;}
> > > > #map {
> > > > width: 100%;
> > > > height: 100%;
> > > > </style>
> > > > var map, world, wms;
> > > > function init(){
> > > > map = new OpenLayers.Map('map');
> 'stadt01']},{isBaseLayer:true});
> > > > </script>
> > > > </head>
> 100px;">Mapnik
> > > WMS Test</h2>
> > > > <div id="map">
> > > > </div>
> > > > </body>
> > > > </html>
> > > > Hope you can help me.
> > > > best regards!
> > > > Nur bis 16.03.! DSL-Komplettanschluss inkl. WLAN-Modem für nur
> > > > 17,95 ¿/mtl. + 1 Monat gratis!*
> > > http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
> > > > _______________________________________________
> > > > Users mailing list
> > > > Users at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/users
> > > Christopher Schmidt
> > > MetaCarta
> > Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit
> allen: http://www.gmx.net/de/go/multimessenger01
> Christopher Schmidt
> MetaCarta
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
