[OpenLayers-Users] [OpenLayers-Dev] this.callbacks is undefined
error
bartvde at osgis.nl
bartvde at osgis.nl
Thu Mar 12 08:49:14 EDT 2009
An old version of OL should be enough. 2.7 will work, maybe 2.6 even works
(have not tested).
Best regards,
Bart
> On Thu, Mar 12, 2009 at 01:26:52PM +0100, bartvde at osgis.nl wrote:
>> Hi,
>> I am not familiar with the Geoserver OpenLayers setup, maybe they
>> generate
>> stuff server-side e.g., but you can just add the FeatureInfo.js file in
>> a
>> <script> tag after the OpenLayers.js script tag. If this does not help
>> maybe check with the Geoserver users list.
> They use a singlefile version of OpenLayers, which isn't a problem in
> and of itself, but the version may be not-the-latest; does the
> GetFeatureInfo control require trunk, or is an olde OL version enough?
> Christopher Schmidt
> MetaCarta
